11 years agoQuartus II Analysis and Synthesis Issues
I have a strange issue with some code I'm working with. I received a Quartus project from TI that should, supposedly, work out of the box. In fact, on the machine running Quartus 2 v13, the code comp...
11 years agoI get identical results to Pete when running it, unmodified, through Quartus 14.1.0 build 186 on Windows 7.
I can cause the Quartus to generate similar errors (and a lot more - can I assume you've just pasted the first couple into your post?) by changing the compiler settings Verilog version to Verilog-1995. You might check that, although that is part of the project settings and not your installation. A long shot but licensing issues often show up in strange ways. You might want to check that. Other than that re-installing v14 doesn't take long although, again, I'm not sure I'd necessarily expect much from that. Or v14 on another machine...? Cheers, Alex
