11 years agoQuartus II Analysis and Synthesis Issues
I have a strange issue with some code I'm working with. I received a Quartus project from TI that should, supposedly, work out of the box. In fact, on the machine running Quartus 2 v13, the code comp...
11 years agoIt seems to be some syntax issue with the .v file. Just wonder if you can try with the latest QII 15.0 to see if it helps?
