Quartus II 21.1.0 STD and ILA opened windows freezes GUI on LINUX at end of fitter.
When I keep the ILA windows under Linux (redhat) while doing a new full place and route to get new probes, using the Ethernet blaster II, when Quartus has finished the tasks (fitter, ..),
Quartus GUI is not responding, no graphics refresh at all.
I'm obliged to bkill quartus, re-open it and re-open the .stp to capture new traces with the ILA.
Could you check if there is a bug in that area?
Alex.
- RichardT_altera
I try with bigger design but unfortunately not able to duplicate the issue.
Since I am not able to duplicate the issue, there is not much that I can help on this.
Perhaps uninstall and reinstall the Quartus may works.
- RichardT_altera
Since the issue is not duplicable, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
- AEsqu
Contributor
While scrolling the setup window under red hat linux using the mouse scroll wheel,
Quartus crashed with this error.
This may point to a problem with the stack size in the ILA.
Would it be possbible to provide a way to increase the stack size of Quartus or the jtag client,
or a quartus patch, to try at my side if that solves the issue?
*** Fatal Error: Unhandled exception
0x8286: ERR_STACKWALKER::get_stack_trace(void const**, int, int, void*) + 0xd8 (ccl_err)
0xb535: err_terminator() + 0x5a (ccl_err)
0x82ae6: __cxxabiv1::__terminate(void (*)()) + 0x6 (jtag_client)
0xb3ef: err_sigaction_handler + 0x7a (ccl_err)0x4c4274: QCompleter::popup() const + 0x4 (Qt5Widgets.so.5)
Exiting...
