Quartus II 21.1.0 STD and ILA opened windows freezes GUI on LINUX at end of fitter.
I tried on both Window 10 and Linux (RHEL) but unfortunately not able to duplicate the issue, with both Quartus and signal tap GUI open & compile at the same time.
ps: I tried using the simple design example below. Example_ISSP_SignalTap.qar, in case this is design dependent issue and you may try to duplicate from your side.
Unfortunately without a way to duplicate the issue, I am not able to further debug. Unless you can give me some pointer to duplicate the issue, else we can only hope someone from the community who comes across similar issue may have some answer.
Richard Tan
Please try with a big design at your side (that uses at least 70% of the FPGA for example).
I don't have access to your example:
403
FORBIDDEN
You don't have permission to access this page due to system time out or privacy restrictions. Please refresh your browser to confirm log-in credentials. Contact System Administrator if access issues persist.
2022-06-28 13:34:49 | Error 403 | https://learning.intel.com/Developer
