AEsqu
Contributor
4 years agoQuartus II 21.1.0 STD and ILA opened windows freezes GUI on LINUX at end of fitter.
When I keep the ILA windows under Linux (redhat) while doing a new full place and route to get new probes, using the Ethernet blaster II, when Quartus has finished the tasks (fitter, ..),
Quartus G...
RichardT_altera
4 years agoI am quite stump as to why the GUI hang.
Does this issue occur with a specific design?
If run the same design by using different machine (with higher RAM), will the issue re-occur?
AEsqu
Contributor
4 years agoWe have machines with huge amount of RAM.
The issue happens with big design in the VQM from Synplify.
If the VQM is big but code get's optimized away (tie clk/rst), then Quartus is fine with Signal tap (only top level remains, 5% usage or so of the FPGA).
