AEsqu
Contributor
4 years agoQuartus II 21.1.0 STD and ILA opened windows freezes GUI on LINUX at end of fitter.
When I keep the ILA windows under Linux (redhat) while doing a new full place and route to get new probes, using the Ethernet blaster II, when Quartus has finished the tasks (fitter, ..),
Quartus G...
RichardT_altera
4 years agoDo you see any error message or Internal Error window pop up? It will be hard to pinpoint the issue that you are facing.
Does you see this issue with a specific design? Does the Quartus tool compile successfully before?
Have you try to run it in a different machine?
Have you check that your OS version support the Quartus software?
Richard Tan
AEsqu
Contributor
4 years agoNo error message, everything is frozen.
No problem when I close the ILA windows before place and route is over.
Well, If I open the ILA (.stp) after the place and route is over, the busy circle runs forever.
So I can only use the ILA by closing Quartus , re open the project and re open the ILA.
