Quartus II 20.1 does not find USB Blaster I (download cable)
When the driver was installed, did you get any pop up or notification saying : USB device not recognize?
Or what is the message that show quartus did not find USB blaster?
Also, you can also try some tips from here:
https://www.drivereasy.com/knowledge/solved-usb-device-not-recognized-in-windows-10-2/
Let me know how if it works or not.
Aiman
- TOMSZ5 years ago
Hi Aiman,
Here is the error message I get as well as pictures of the driver states.
Also, I tried the tips from the link you provided. None of them worked.
I believe the problem is the expired driver certification. In the beginning of June I was able to use the USB Blaster with Quartus with no issues. Later, at the end of July when I tried to use the same USB Blaster with Quartus, the USB Blaster was not found and programming a FPGA no longer worked.
TOMSZ
