11 years agoI found it takes longer to compile (web-edition) but it is "better" in a sense that it has fewer warnings and on one time was able to keep within the timing requirements where 13.1 could not. But it takes about 5 times longer with the same settings in a project with a lot of hierarchy levels and components.
Also I just used the RTL Viewer, and it is farmore easier to use, and looks way better.
