11 years agoQuartus II - Design Partition
Hi everyone,
I've used Design Partition to fix post-fit routing in a project. We are archiving the Quartus project under SVN. Do you know which files I need to commit to SVN for anyone to be able to reproduce post-fit results with the Design Partition settings? I've seen the first time the Design Partition is used for fitting, there is a warning message saying: "Warning (35009): Previously generated Fitter netlist for partition "ddr_out:ddr_out_inst" does not exist -- using previously generated Synthesis netlist instead" It seems that the fitter netlist shall be kept to reproduce the results. Thanks in advance, JG5 Replies
The files should be when you export the design partition in the post fit format in qxp. Then you should be able to import this design partition
Hi kennyboy2020,
I've exported the qxp files and committed them to the SVN repository. In a clean checkout from the SVN repository, I've ran a new compile, and timings results are not the same! I still have the same warning... Maybe I'm doing something wrong with the qxp files... JG - Altera_Forum
I guess file a service request will be better, unless you willing to post your project here. ;)
You may also consider direct contact your local distributor to see for prompt response. The distributor can also help you file case to Altera if needed.
Thanks for the replies :-) JG
