8 years ago[Quartus] how to define the compilation libraries for VHDL files?
Hi All, In Quartus Prime, how can I define the compilation library each VHDL file? For example, I'd like the file top.vhd file will be compiled into 'work' library and all the *_pkg.vh...
8 years agoBTW, does Quartus Prime supports the context statement?
I'm receiving the following error:Error (10500): VHDL syntax error at t_all.vhd(6) near text "context"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration" for the following file contents (this file is defined as VHDL-2008 file in the Project Settings):
context t_all is
library pkgs;
use pkgs.t_bit.all;
use pkgs.t_lpfsm.all;
use pkgs.t_des.all;
use pkgs.t_fifo.all;
use pkgs.t_ports.all;
use pkgs.t_tbl.all;
end context t_all;
It seems Questa Prime does not recognize the context keyword... So, how to fix/workaround? How can I use VHDL-2008 context statements with Quartus Prime? I'm using QuestaPrime v16.1. Thank you!
