Dirk3
4 years agoQuartus graphical toplevel(bdf) no error for missing source signal
The compiler brings no error for exsisting signals, even if they have no source.
Is there an option to enable compiler errors for such a case, if signals have no source.
Best Regards
sstrell
4 years agoMost designs do not have hundreds of unused inputs. Even if you set these I/O as ports in your top-level HDL, the Fitter will select temporary I/O pins to prevent logic from being optimized away.
If you really need to preserve all of those inputs and you have a list of them, you can easily copy and paste them into the To column in the Assignment Editor to create virtual pin assignments for each. And of course, you only need a single assignment for a bus using wildcards.
