I can suggest you to refer to the document:
http://www.altera.com/literature/hb/qts/qts_qii53011.pdf and to use at least Quartus version 8.0 if you have not upgraded it. It seems that some bugs were fixed recently in the Conformal Verification procedure. - Altera_Forum
hi, thanks for the pointer. i am following the steps in this document to enable netlist/conformal setupfile generation. I am also using QuartusII 8.0 build 231 07/10/2008 SP1 SJ Full Version (PC version) which i thought was the latest version.
Yeah, it's indeed the last one. Unfortunately now I've got no more suggestions, I've never gone into this error. Maybe someone else can help?
Cheers OD
