quartus "create_revision"tcl指令执行错误
Translated:
quartus "create_revision" tcl instruction execution error Error(16546): Cannot load final database-ensure all earlier stages of the compiler have completed. When using the "create_revision rev_1 -based_on base_revision" tcl command, the above error will always be reported, but the window selection input will not.
Try to recompile the design beforehand using the below tcl command.
execute_flow -compile
Then try to run the create_revision tcl command to check if the error solved.
p/s: If this was helpful, please feel free to give Kudos.
该问题已经解决,不是没有编译的原因。而是tcl指令不全导致的,完整的tcl指令如下:
”create_revision persona5 -based_on pr_tcl_test -new_rev_type impl -root_partition_qdb_file root_partition.qdb -set_current“,即增加了-new_rev_type impl
- RichardT_altera5 years ago
Great to hear that you are making progress! I’m believe that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from you, the community or Intel support are helpful, please feel free to give Kudos.
