HKim27
7 years agoQuartus crash with "Internal Error: Sub-system: THR"
Hi, all. I use Intel® Acceleration Stack Version 1.2 with Intel® Programmable Acceleration Card with Intel Arria® 10 GX FPGA on CentOS Linux release 7.2.1511. When I compile my design, Quartus keep...
- 6 years ago
Hi, I actually solved the problem yesterday.
My compile system uses Lustre filesystem. The filesystem setup was a bit broken, and it was returning ENOSYS for fcntl(..., F_SETLK, ...) call.
After fixing the filesystem, compilation works perfectly.
Here is the script I used to debug:
#include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <stdlib.h> #include <stdio.h> #include <errno.h> int main() { int fd = open("a.txt", O_RDWR); if (fd == -1) { printf("open error (errno=%d)\n", errno); exit(1); } struct flock lock; lock.l_type = F_WRLCK; lock.l_whence = SEEK_SET; lock.l_start = 0; lock.l_len = 1; int ret = fcntl(fd, F_SETLK, &lock); if (ret == -1) { printf("fcntl error (errno=%d)\n", errno); exit(1); } printf("no error\n"); return 0; }If someone get "fcntl error (errno=38)", that's the problem.
MEIYAN_L_Intel
6 years agoHi,
I had received and downloaded the file. I would like to have sometime to setup the environment.
