Jamil
7 years agoQuartus crash! The quartus prime software quit unexpectedly! Could some body help? Thanks please see details below.
Problem Details Error: Internal Error: Sub-system: STA, File: /quartus/tsm/sta/sta_odv.cpp, Line: 643 Try setting the quartus.ini sta_odv_clock_path_dfs_max_depth=<integer> to a greater value (cur...
Abe
7 years agoLooks like the tool crashed during TIming anlaysis (STA). Have you tried the suggestion mentioned in the error file to see if it goes through?
Try setting the quartus.ini sta_odv_clock_path_dfs_max_depth=<integer> to a greater value (currently 33, -1 for unlimited).
Edit the quartus.ini file and search for the above line and set it at a higher value then -1 or 33. Try a few values and see if the STA goes through.
