11 years agoQuartus compiles slow in Arch Linux
Recently I found out that Quartus II 15.0 compiles really slow in Arch Linux. A nearly empty cyclone IV project took ~4 min to compile While the same project took about 30sec to compile in Windo...
11 years agoThank you for the interesting solution...
Turn off the internet connection indeed make it run fast... I suspect it is a software bug. A practical workaround may be run quartus in unshare http://linux.die.net/man/1/unshare to block internet connection... But if you are using an ip license, quartus_asm must be run with internet, or else no .sof file would be generated. Hope quartus could fix the bug soon.
