8 years ago
quartus compile error Case choice must be a locally static expression
i compile a code in quartus that has case-when statements nested in a for loop and each value checked depends on the loop variable.
Quartus complains on this with the error 'Case choice must be a locally static expression'.
Is there any workaround for this problem? it would be manually hard to unroll the loops.
I tried to change vhdl version to 2008 but did not help. I also saw some discussion on setting a parameter --relax <someting>...
For the record, this case-when statements did not produce an error when compiling on Sinplify
1 Reply
    Posting the code would help to understand what's wrong.
