We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
One more thing. Perhaps this will help. Also see my 11-29-2021 06:39 AM reply. The date is later than yours, but it is listed as an earlier post.
In Quartus 16.0 the "DDR3 supporting UniPHY" controller is listed as part of the Altera IP Base Suite in the license file (see below).
# The following is a license file for the Altera IP Base Suite (FFT, NCO, DDR / DDR2
# SDRAM, DDR / DDR2 / DDR3 SDRAM supporting ALTMEMPHY, DDR2 / DDR3 supporting UniPHY,
# RLDRAM II, RLDRAM II supporting UniPHY, QDRII, QDRII / II+ supporting UNiPHY, FIR
# Compiler II, LPDDR2)
It is not listed as part of the Base IP Suite in the license file for Quartus Standard 21.1 (see below).
# The following is a license file for the IP Base Suite Package part number for IP
# Base Suite (NCO, FFT, FIR Compiler II)
Quartus Standard 21.1 apparently allows me to upgrade the DDR3LP controller since it does not issue any errors when I do the upgrade, only later when I try to compile. Perhaps this is a clue.
