TJohn
4 years agoQuartus compile error after upgrade from Quartus 16.0 to 21.1
Quartus issued the following compile error after upgrading a design that compiled correctly with Quartus 16.0 Std to 21.1 Std, "12006 Node instance ".." instantiates undefined entity "..". Ensure th...
sstrell
4 years agoJust copying the design to a new location with a new name may be your issue. Did you use the project copy command or create a project archive?
If you're still getting the same error about library paths for just that IP, I'd delete the IP files and then add it back to your design, going through the parameter editor again.
