15 years agoQuartus compilation warnings
When I compile a Quartus project, with a nios system, I always have a lot of warnings like the following ones.
I've never had any problem with the designs; everything works perfectly. However I wonder if these warnings are normal or if I have some problem in project settings.Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning: Using design file TSE_NIOS_clock_2.vhd, which is not specified as a design file for the current project, but contains definitions for 10 design units and 5 entities in project
Info: Found design unit 1: TSE_NIOS_clock_2_edge_to_pulse-europa
Info: Found design unit 2: TSE_NIOS_clock_2_slave_FSM-europa
Info: Found design unit 3: TSE_NIOS_clock_2_master_FSM-europa
Info: Found design unit 4: TSE_NIOS_clock_2_bit_pipe-europa
Info: Found design unit 5: TSE_NIOS_clock_2-europa
Info: Found entity 1: TSE_NIOS_clock_2_edge_to_pulse
Info: Found entity 2: TSE_NIOS_clock_2_slave_FSM
Info: Found entity 3: TSE_NIOS_clock_2_master_FSM
Info: Found entity 4: TSE_NIOS_clock_2_bit_pipe
Info: Found entity 5: TSE_NIOS_clock_2 Regards Cris
