AEsqu
Contributor
4 years agoQuartus 21.1: Error (10170): Verilog HDL syntax error at ... near text: "import"; expecting ";".
module ethosu55_sb import ethosu55_pkg::*; import ethosu55_mac_pkg::*; #( parameter npu_config_t CFG = BUILD_CFG(0,0) )
Gives this quartus error: Error (10170): Verilog HDL syntax error at et...
AEsqu
Contributor
4 years agoI dowload the related imported package using this in the .qsf:
set_global_assignment -name SYSTEMVERILOG_FILE -lib ethosu55_lib ${data}/ip_arm_lib/ip_hactar_256/ethosu55/logical/ethosu55/verilog/ethosu55_pkg.sv
set_global_assignment -name SYSTEMVERILOG_FILE -lib ethosu55_lib ${data}/ip_arm_lib/ip_hactar_256/ethosu55/logical/ethosu55_mac/verilog/ethosu55_mac_pkg.sv
And the RTL itself that contains the import (later in the qsf, not before the two previous files):
set_global_assignment -name SYSTEMVERILOG_FILE -lib ethosu55_lib ${data}/ip_arm_lib/ip_hactar_256/ethosu55/logical/ethosu55_sb/verilog/ethosu55_sb.sv
