VSavi3
4 years agoQuartus-21.1.0.842 Fitter problems
I have a design which compile and fit properly in Quartus_19.1.0.670 version.
But exactly same design does not fit when I use Quartus-21.1.0.842. It gave me following error.
I tr...
sstrell
4 years agoHow full was the device in 19.1? I'm guessing very full. It's possible some optimization did not occur when you moved to the new version or the function of a particular optimization changed.
Or are you using design partitioning/block-based design or Logic Lock regions?
sstrell
4 years agoAlso, you're showing the generic message, not the actual error message. What resource is Quartus saying you are overusing?
You should also try, at least temporarily, disabling design partitioning to see if that is part of the issue (which I'm guessing it is).
