Mircea
5 years agoQuartus 20.3 pin file
I just moved a Stratix10Mx project from Quartus 19.2 to Quartus 20.3.
The Q20.3 generated pin file shows unused dedicated GX Rx pins to be "NC".
The same pins in the Q19.2 generated pin ...
CheepinC_altera
5 years agoHi Mircea,
Sorry for the delay. I might have overlooked the email notification on the latest post. For your information, we should follow the pin connection guidelines where the unused GXB_RX should be grounded.
As I understand it, the .pin file seems to serve as input to your schematic tool. As a workaround, to allow you to proceed, I would recommend you to perform a diff between the Q19.2 pin file vs Q20.3 pin file. Then you replace the the unused GXB_RX from "GXB_NC" to "GXB_GND*" in the Q20.3 pin file.
I will file a case to Factory highlighting this for future Quartus fix.
Chee Pin
