Mircea
5 years agoQuartus 20.3 pin file
I just moved a Stratix10Mx project from Quartus 19.2 to Quartus 20.3.
The Q20.3 generated pin file shows unused dedicated GX Rx pins to be "NC".
The same pins in the Q19.2 generated pin ...
Mircea
5 years agoHello Chee Pin,
Thank you very much for asking.
Yes, I am very concerned.
My concern is that I can't use the Quartus 20.03 generated pin file.
As you requested, I made a simple project with only one input and one output.
The resulting pin file has the unused GXB_Rx pins as "NC", while the guidelines note has them connected to GND.
I attach the pin file and the project.
I really need an answer to this ASAP, since this prevents me from finishing the schematic.
Mircea
Mircea
5 years agoHello,
I really need an answer to this.
I use the pin file to create the actual schematic for the board, using the Stratix10.
Not having a correct pin file prevents me from continuing with my work.
Can anybody help?
Mircea
