Quartus 20.3 pin file
As I understand it, you have some inquiries related to the .pin file difference between Q19.2 vs Q20.3 for the unused XCVR pins. Thanks for attaching the files, I will further look into them to see if can spot any anomaly.
Meanwhile, just would like to check with you if you have had a chance to try with freshly created simple design in Q20.3 with the same device and run through compilation to see if there is any discrepancy in the generated .pin. This is to help isolating any migration related issue.
Chee Pin
- Mircea5 years ago
Hello Chee Pin,
Thank you very much for asking.
Yes, I am very concerned.
My concern is that I can't use the Quartus 20.03 generated pin file.
As you requested, I made a simple project with only one input and one output.
The resulting pin file has the unused GXB_Rx pins as "NC", while the guidelines note has them connected to GND.
I attach the pin file and the project.
I really need an answer to this ASAP, since this prevents me from finishing the schematic.
Mircea
- Mircea5 years ago
I really need an answer to this.
I use the pin file to create the actual schematic for the board, using the Stratix10.
Not having a correct pin file prevents me from continuing with my work.
Can anybody help?
Mircea
