FBels
5 years agoQuartus 20.1.1 usb blaster install getting errors
Installs in the past 2 weeks of Quartus on freshly imaged Windows 10 laptops are failing for multiple engineers here. The failure is from the USB Blaster driver installation process.
The issue see...
JohnT_Altera
5 years agoHi,
Sorry for the confusion, what I mean is that the issue is similar between USB-Blaster and USB-Blaster II except that the directory location is different. So you can use the similar step to disable the driver signature then only install the usb-blaster driver.
FBels
5 years agoCompany IT security does not allow "disable the driver signature".
When will a valid signed usb-blaster driver be available?
