FBels
5 years agoQuartus 20.1.1 usb blaster install getting errors
Installs in the past 2 weeks of Quartus on freshly imaged Windows 10 laptops are failing for multiple engineers here. The failure is from the USB Blaster driver installation process.
The issue see...
JohnT_Altera
5 years agoHi,
Yes, it will be applicable to both blaster and blaster ii
FBels
5 years agoJohn T --
The usb blaster ii driver update succeeded, but my original issue regarded USB Blaster classic driver.
When you said the driver applies to both USB Blaster and Blaster II -- the drivers have different driver directories in Quartus installation c: drive areas. EG ../drivers/usb-blaster and ../drivers/usb-blaster-ii.
For the manual Windows work-around, are you saying to copy the downloaded usb-blaster-ii driver files also to C:\intelFPGA_lite\19.1\quartus\drivers\usb-blaster? And rename them usb-blaster.cat and .inf?
The .zip file I downloaded from intel a while back only contains files named usbblasterii.cat, usbblasterii.inf.
