FBels
5 years agoQuartus 20.1.1 usb blaster install getting errors
Installs in the past 2 weeks of Quartus on freshly imaged Windows 10 laptops are failing for multiple engineers here. The failure is from the USB Blaster driver installation process.
The issue see...
JohnT_Altera
5 years agoHi,
I would recommend you to download the latest Quartus Programmer which will have a newer driver signature.
FBels
5 years agoDownloaded Quartus Programmer SW QuartusProgrammerSetup-20.1.1.720-windows.exe
Told installer to create and use this directory "C:\intelFPGA\20.1.1_prgmr"
Run as Administrator.
The install selection page did not show the USB Blaster. It did show USB Blaster II. My PC had a USB Blaster connected to it. Installation failed at the Driver install step.
I uninstalled and replaced the USB Blaster with a USB Blaster II. Installation still fails at the Driver install step.
