Quartus 2 Using Enviorment
I want to use it on 64Bit of Windows no matter what.
The latest version is good.
What should I do?
- KennyT_altera
Do you mean latest version Quartus Prime Std 20.4? It should be supporting 64bits of windows 10.
- YMFK_Engineer
- Current version: 7.1
- Reason for Change
: Improve Test Problem
* 10CL016Y
Windows7_32Bit_7.1 = NG
Windows10_64Bit_17.1 = PASS
- I want to use the latest version that supports 10CL016Y on 32Bit.
- ak6dn
Not possible.
Starting with Intel® Quartus® Prime Software version 14.0, Intel® FPGA software only supports 64 bit versions of the OS.
The earliest version of Quartus softwarre that supports the CY10LP series is 17.0
So you MUST install and run Quartus on a 64b version of Windows 7 or 10.
- KennyT_altera
When you mention 7.1, are you referring to Quartus version?
- KennyT_altera
any update from the previous queries?
- KennyT_altera
We do not receive any response from you to the previous reply that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
