12 years ago
Quartus 2 Chain debugger
I have a chain with 3 bs devices : 1 EP3SE200
2 EP3SE260
3 VSC82244
If i am in Quartus II programmer debug mode this chain is correct seen, all device id's are seen.
Also with our boundary scan test (jtagtooling there's no problem with this chain.
But if I am in the Quartus II programmer and try "auto detect" nothing is seen, this message appears : "Can't scan JTAG chain"
Also adding the devices manualy does not work, a "fail" appears.
Any idea ???
Thanks Hans
1 Reply
    The problem was(is) the VSC8244, to bypass the device according 1149.1 must be 1111 . The VSC8244 is ONLY: 0111.
    Quartus wants to put the device in Bypass during programming and uses 1111. This was causing the programming problem.
    Hans
