11 years agoquartus 2 14.1 web : NO sof file
i did a simple And through Block Diagram. look like this
[url=http://s77.photobucket.com/user/leepialong/media/and.jpg.html]http://i77.photobucket.com/albums/j71/leepialong/and.jpg (http://i77.photobucket.com/albums/j71/leepialong/andwarning.jpg)[/URL] after i assigned the pins and complied, i got this warning: [url=http://s77.photobucket.com/user/leepialong/media/andwarning.jpg.html]http://i77.photobucket.com/albums/j71/leepialong/andwarning.jpg (http://i77.photobucket.com/albums/j71/leepialong/andwarning.jpg)[/URL] i cant find SOF file any where in the folder4 Replies
after complied, i got few warning but no error but why Quartus doesnt make any SOF file?
my designed: http://i77.photobucket.com/albums/j71/leepialong/and.jpg (http://s77.photobucket.com/user/leepialong/media/and.jpg.html) warnings: http://i77.photobucket.com/albums/j71/leepialong/andwarning.jpg (http://s77.photobucket.com/user/leepialong/media/andwarning.jpg.html) - Altera_Forum
Hi zombot,
It seems like you might have missed out the warning messages in your post. By the way, probably you could double check if there is any issue with license setup? - Altera_Forum
check on the assemble report, it should show clearly why your sof file is not generated.
The sof file should be saved in "output_files" folder by default. Check on the output file directory in Settings/Compilation Process Settings
