Quartus 19.1 license issue.
- SKinz7 years ago
Thanks. The situation I have is that the machine running the license manager is using Redhat 5.1 and at the moment I cannot upgrade the OS on this machine. Redhat 5 doesn't support the later daemons. I can run under ubuntu 16.04 or later but would need to switch to another machine. Our authcodes expire in August so at a minimum we'll switch then. Is there a possibility of getting a temp license file to test on a new machine before then? I tried generating a companion license on the licensing support site but that didn't actually do what I wanted. It appeared to link back to the manager running on the old machine so I couldn't shut down the manager on the old machine to test if the new file would work against the NIC on the machine I want to move to.
Skip
