MJone6
8 years agoQuartus 18 not starting jtagd with tty causes failure
On Ubuntu 16, I can start jtagd on the command line and quartus 18 can use usb blaster, but when quartus starts jtagd itself, it can't communicate with usb blaster. When I ps -ef | grep jtagd, the on...
MJone6
8 years agoNooraini,
Selecting the “Dual Compressed Image”s does not add this line to the qsf file:
set_global_assignment -name ENABLE_NCONFIG_FROM_CORE ON
And the default version of the assignment is OFF. Therefore, signaling a reconfig using the IP fails.
The solution of manually editing the qsf with a text editor is non-obvious and undocumented.
See image below.
Mike
[cid:[email protected]]
