MJone6
8 years agoQuartus 18 not starting jtagd with tty causes failure
On Ubuntu 16, I can start jtagd on the command line and quartus 18 can use usb blaster, but when quartus starts jtagd itself, it can't communicate with usb blaster. When I ps -ef | grep jtagd, the on...
Nooraini_Y_Intel
8 years agoHi MJone6,
Apologize for the delay response. I needed time to find a machine that I can install Ubuntu 16 as all the machines here Windows OS. So, I managed to installed Ubuntu 16, then Quartus Lite v18.0 tools and the USB Blaster driver. After the installation I restart the machine.
1) Open Quartus 18 on Ubuntu 16
2) Create a new project design --> Compile to generate a .sof file
3) Open Programming tool
4) Select USB Blaster
5) Perform auto-detect --> Successfully detect MAX 10 device on the dev kit
6) Add .sof file into the programmer
7) Click start --> Programming start until progress bar show 100% success
I'm not able replicate the issue that you are seeing. Can you provide some screen shot showing the issue?
Nooraini
