8 years agoQuartus 18 MegaWizard issue
Hi all! I just have installed Quartus 18.0.0 to test it and got an issue with MegaWizard Plugin. I am using Ubuntu 16.04 X86_64 machine. What I do: 1. Create a new empty project wit...
MPfaf1
7 years agoIdea on the reason for this issue:
- Start <Quartus_Install_Path>/intelFPGA/18.0/quartus/bin/qmegawizq
- Choose "Edit an existing custom..."
- Search for the .v/.vhd file you previously generated for your megafunction
- Megafunction name has to be set to "Altera PLL v18.0"
- Clicking Next button shows where the error comes from: Naming has changed "PLL Intel FPGA IP v18.0" . Intel seems to have forgotten to change the Altera naming in the library.
LLuga
7 years agoMy quartus version is 18.1,NowI have the same problems.I try to use your idea to solve my problem,but I failed.Could you tell me more about the detials.Operation flows is better.Thank you very much.😁
