Quartus 18.1 still broken.
we appreciate your efforts and patience.
we request you all, for better support,please open multiple threads instead of single thread with multiple queries.
Step 1 : With reference to Fig. 6 :
please first modify the .lst file(Since it is temporarily solution) as suggested in Fig .9 from the installed directory & path may similar like below & check screen shots as well,
C:\intelFPGA\18.1\ip\altera\ethernet\altera_eth_tse
Step 2 : from "Upgrade Tool" click on "Failed" IP & generate again..
Step 4 :
"When I attempted to attach the .lst files, the ANSWER button was grayed out, so I added a .txt suffix (yet another issue with the forums)."
I also realized same behavior & it might happen during maintenance or .lst is not supported.
Step 5:
"When I do a File -> Open on MAIN_PLL.vhd (the generated core) it just opens MAIN_PLL.vhd (same for EMAC.vhd) instead of the wizard. Things like the FIFO open in the wizard as expected."
Now check below,
Step 6:
Successfully upgraded & Compiled.
Best Regards
Vikas Jathar
