ADelp
7 years agoQuartus 18.1 not programming .pof file. .sof file works fine. Says it passes if I don't enable real-time ISP but it doesn't work. Fails if I enable real time ISP.
I have tried every combination of the Program/Configure check boxes with and without real-time ISP checked. I have also tried doing it after I successfully load in the .sof. I have followed section ...
Nooraini_Y_Intel
7 years agoHi ADelp,
Thanks for the update, it's good to know that you were able to resolve the issue. To answer your question yes, in the MAX 10 JTAG setup the nCONFIG, nSTATUS and CONF_DONE are require to be pull up to VCCIO voltage level via 10kohm pull up. You can refer to chapter 3.2.3. JTAG Configuration Setup in the following MAX 10 device Configuration user guide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Nooraini
