Click_Er
8 years agoQuartus 15.1 Control + C does not work
Using Altera Quartus 15.1 on Intel i7, 64 GB RAM on Win 10. Text editor, copy feature via Control + C does not work. I have Altera Quartus 15.0 and 15.1 installed. I need both versions installed. Con...
KhaiChein_Y_Intel
7 years agoHi Click_Er,
I tried to launch both v15.0 and v15.1 in Win 10. The CTRl + C works in both versions.
Have you try in other machine? Could you use right click > copy as a workaround?
elifino
6 years agoThis is still a bug in 20.1. Judging from the responses, apparently it depends on random variables specific to some installations, so I wonder if it'll ever get fixed.
I've found two work-arounds: Use Ctrl-Insert instead, or just get used to using Ctrl-X/Ctrl-V in rapid succession, which has the same effect.
