Quartus 14 Avalon BFMs - Qsys generate error
Hi, I am having the same issue. I am trying to open the component editor, but I can't seem to find a way to open it for an existing component. Every manual I read just shows how to open it for new components. I am using quartus prime version 20.2.0 Pro edition. If you can help me out with this, I'd greatly appreciate it.
You can't make changes to an off-the-shelf component with the Component Editor.
What are you trying to do?
- Eduardo19875 years ago
I am trying to simulate the top level of a design. To do so, I was trying to run the "ip-setup-simulation" utility. When I ran it, I got about 430 errors where SPD files were not found. To fix that, I ran qsys-generate on each qsys system in the design for simulation, and after doing that, I reduced the errors to 16 SPD files not found. When looking at the output of the qsys-generate for those specific ip cores, I noticed the same error message as in this threat: "..does not support generation for Verilog Simulation. Generation is available for: Quartus Synthesis". I've seen a couple of threats with similar errors stating that this can be fixed specifying simulation files in the "files" tab in the component editor as shown in this threat, so I was trying to do the same to fix my issue. Any help would be appreciated.
- sstrell5 years ago
What IP are you trying to simulate? They may not support Platform Designer testbench simulation and may require a different method to simulate.
