13 years agoHere is the solution using the full package;
untar/zip the package to a temporary directory e.g /tmp/altera > tar zxvf 12.0sp2_263_quartus_free_linux.tar.gz > cd 12.0sp2_263_quartus_free_linux >./setup The installer gui will show up. Install the required parts at the required location e.g. : /opt/altera12/quartus. Do not let the tool remove temporary files. go to cd linux_installer/quartus_free_64bit Type the full pathname of the directory where you want to install the Quartus II software (64-bit) 12.0sp2 software when asked for. The installer will report "An installation of Quartus II software (64-bit) already exists in '/opt/altera12/quartus" "Do you want to remove it before installing Quartus II software (64-bit) 12.0sp2? (y/n):" Answer : No It will install the 64-bit parts of quartus now, (with some warnings) When this has finished the following directory can be removed altera_install This work is not mine and found this on a swedish website. http://www.ict.kth.se/courses/is1500/2012/swsetup/quartus12linuxinstall.txt The instrcutions work both for Ubuntu and Slackware 14.0 (tried them both myself) grtz ST
