Altera_ForumHonored Contributor13 years agoQuartus 12.0 sp2 on slackware 64bit I have finally managed to install quartus_free on my slackware box, using the full package and not the installer. For this I also needed to install multilib, ia32 alike, and 32bit compatible libra...Show More
Altera_ForumHonored Contributor13 years agoPossibly I have found the solution. I'll post the results soon.
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
