Quartus 11.1 Text Editor Copy+Paste problem
I found a problem using Quartus text editor: when using copy/paste with Ctrl+Ins/Shift+Ins, Quartus pastes several times instead of just a single paste. It happens when I copy/paste a word that found more than one time in a document. When using Ctrl+C/Ctrl+V everything works fine.
No problems for me.
Have you installed service pack 1? - Altera_Forum
Yes, service pack installed, it did not help.
If I switch off "Tools\Options\Text Editor\Highlight similar instances of a selected word" the problem disappears. - Altera_Forum
That option is enabled for me.
Is this windows or linux? - Altera_Forum
also worked for me
WinXP and Win7 the same effect
ahhh i have finally duplicated your problem, and found another related bug
the highlighting feature is pretty new, so i guess we've found it's not well tested i will file SRs on both issues if you haven't already - Altera_Forum
No, I did not file SR
i did on both issues. thanks
I find that if I cut and paste a bunch of times using control C and Control V, then quickly type something. The tool will hang with a severely blocking thread and you need task manager to kill the program.
Also, I get a pesky "file was modified, would you like to reload it? blah blah" that pops up over and over again. Quartus 11.1 is a big step down, but I need it for cycloneIV GX part. - Altera_Forum
Turning off the highlight thing sounds like a good idea. I will try that.
