14 years agoQuartus 10.1sp1 and upgraded Eclipse wont debug
we run quartus 10.1 sp1 so our projects are backward compatible with hardware designed a year back. the Eclipse package will not enter debug mode, because I justed updated Eclipse from 1.2.1 to 1.2.2 using the update button inside eclipse help platform. that is not the problem I get errors in the console error log saying the following:
The SOPC design does not contain a CPU of a supported architecture The CPU module is not set. SOPC design not set. CPU master group not set. all these errors are logged by plugin com.altera.sbtgui.launch. problem is previous version of Eclipse gave me these errors, but entered debug mode, new updated version gives me same errors, but does not enter debug mode. Where do I set or configure these settings?? :evil: The actuall error that pops up in windows says: "Error Creating Session" {R,T}x Thread terminated and then it says the errors listed above Also in the Console window it says: Using cable "USB-Blaster [USB-1]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x00002000: verified Listening on port 51682 for connection from GDB: 59s58s57s56s55s54s53s52s51s50s49s48s47s46s45s44s43s42s41s40s39s and it will Run doing Run as NIOSII Hardware, but it will not debug doing Debug as NIOSII Hardware??
