9 years ago[Quartus & Modelsim-Altera] simulation of altera's megafunction components
I have generated a pll using the Quartus IP-Core.
I have created a simple testbench which includes the pll. The project top compiles successfully, However when I launch the RTL simulation tool(Modelsim-Altera) the modelsim raise an error
alt_pll.v(67): Instantiation of 'altpll' failed. The design unit was not found
At the library panel I can see the library called "altera_mf" But it seems like modelsim search for libraries only in rtl_work library and not in the pre-compiled libraries of modelsim-altera. How to set modelsim to load the precompiled libraries ? Thanks2 Replies
Anyone here, could help with a Modelsim installer in a W7? I will need a Sw and craker..... Kind regards,
--- Quote Start --- I have generated a pll using the Quartus IP-Core. I have created a simple testbench which includes the pll. The project top compiles successfully, However when I launch the RTL simulation tool(Modelsim-Altera) the modelsim raise an error
At the library panel I can see the library called "altera_mf" But it seems like modelsim search for libraries only in rtl_work library and not in the pre-compiled libraries of modelsim-altera. How to set modelsim to load the precompiled libraries ? Thanks --- Quote End --- Try adding following to your vsim command "-L altera_mf" or use the Native link simulation to setup simulation https://www.youtube.com/watch?v=pmvvxqchv2c Best Regards, arslanusman2003 (This message was posted on behalf of Intel Corporation)alt_pll.v(67): Instantiation of 'altpll' failed. The design unit was not found
