9 years agoQuartus - Technology Mapper option
Hello. At Altera Quartus Prime Standard Edition Settings FileReference Manual in some descriptions i found a "Technology Mapper option". Where in the application can I find these settings? I need thi...
9 years agoChosing the mapping can be done with attributes in HDL - but this will only work if the logic is suitable. Why not post the code so we have some idea of whether it will work.
As a note though, Quartus will generally use Memory elements when it can, and only use LUTs if necessary. If it didnt default to RAM, there is probably an issue with the code.
