Altera_ForumHonored Contributor13 years agoQuartus - assembler not generating sof file Hi, By default Quartus assembler generates sof file, however, it's no more in our case. Any particular settings that is causing this ? The Quartus I am using is not an evaluation copy. Thank...Show More
Recent Discussionshow to reduce clock skew between synchronous clockQuartus 13.1 including Signal Tap LicenseI do not get an eMail with the generated license fileInstaller cannot establish connection with SSL errorQuartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
