Altera_ForumHonored Contributor13 years agoQuartus - assembler not generating sof file Hi, By default Quartus assembler generates sof file, however, it's no more in our case. Any particular settings that is causing this ? The Quartus I am using is not an evaluation copy. Thank...Show More
Altera_ForumHonored Contributor12 years agoThe warning tells you the problem - you dont have a valid licence.
Recent DiscussionsInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!Licensing ‘Know-How’ Guide
