10 years agoQSYS Testbench Generate Interface not Found Error
Hello all,
I am frequently facing this particular issue is QSYS, while generating a testbench system for multiple times. The generate window shows error as a particular interface is not found. (check the attached image) "can't read "intf_use_partner(asi)";no such element in array" I never had declared/exported that particular interface. The workaround I used to follow is to create a whole new system with different name, but it's a time consuming process. Anyone here has faced the same issue? Expecting a solution asap... Thank you.1 Reply
**Solved**
Looks like a bug in Qsys. Remove all the unnecessary custom IP paths mentioned in IP Search Path and generate testbench again.
