14 years ago
qsys-script problems
Is anyone successfully using the qsys-script tool? It looks like it would be really useful to automate the creation of several similar qsys systems, but I cannot get it to work.
Every tcl command I try and issue it says is invalid. For example below I try to output a simple test message (though I get the same errors with create_system etc). I type into the Nios II Command Shell:
qsys-script --cmd="send_message INFO testmessage"
And I get...
2012.07.30.21:05:30 Info: Doing: <b>qsys-script --cmd=send_message INFO testmessage</b>
2012.07.30.21:05:33 Error: invalid command name "send_message"
It seems odd that the info/error messages contain HTML tags. Am I supposed to be running this in a GUI or some other shell/prompt?
It doesn't appear to make any difference whether I specify the commands using the --cmd argument or in a script using --script.
It looks like this was only added to the Quartus handbook in version 12. I'm currently on 12.0, but I am downloading SP1 to see if that helps.
I'm fairly new to tcl scripting, so is there something really obvious I'm missing here?
Richard.
    send_message isnt a tcl command, it is a function included in a quartus package i believe. this works though:
    qsys-script --cmd="puts hello"
    --dalon
    --- Quote Start ---
    --dalon
    --- Quote End ---
    Thanks for your reply. I got send_message from the command list at the end of chapter 5 in vol 1 of the Quartus handbook. Though I've not tried them all, other commands from that list seem to give the same error message.
    The impression I get from the handbook is that I can just call those commands directly in my script. Perhaps I need to 'include' something (if tcl scripting has such a concept) before they will work?
    Richard.
    Re-reading the handbook, it appears I missed the fact that you need to call qsys-script with the --package-version=<value> argument (or include something similar in my script). First time I read it I think I assumed this was only necessary if I was trying to use a version other than the version of the qsys-script executable, but apparently not. Setting this to 12.0 fixes my problems.
    Richard.
