9 years agoqsys-script: no output on stdout when called from TCL script
Since the TCL interpreter in qsys-script is very limited and outdated I want to reduced the amount of work done via qsys-script to the absolute minimum. However when I call qsys-script from another T...
9 years agoThe output of teh qsys-script call goes into STDERR.
Try to append "2>&1" after your command. This combines STDOUT and STDERR to STDOUT. If you are just interested in your own output from your script and not from qsys-script try to append just: "2>err" or "2>/dev/null". I tested both successfully.
